Mileage: 11,050 * Installed the steering head Tapered
Roller Conversion kit.
* Straight R & R, except that a
spacer washer (part of the kit) replaces the lower tin spacer and the rubber biscuit (on
the bottom of the steering stem) to become the seat for the lower tapered roller cage.
What a difference this
conversion makes! No more sloppy steering action and no more of those insane rollers
(19 top and 19 bottom) that bounce all over your garage.
* Drained the fork tube oil
overnight. Refilled with 200cc of ATF (enhanced seal rejuvenation formula).
Recommended amounts vary from 200cc to 250cc (6.8 to 7.1 oz). Note: this volume applies to the early,
steel bottomed forks.
The recommended oil type ranges from "White Spindle Oil # 60" - per Honda
Factory Service Manual, to anywhere from 5wt, to 10wt to 10W30 as reported by VJ veterans.
* The left tube showed signs of oil
seepage from the seals and with the wheel off, the action of that tube was somewhat
"sloppy," with some internal scuffing or roughness? A rebuild is
definitely in order for the left tube; hopefully it can be saved!
With fresh oil, the damping
action is greatly improved, although I will probably experiment with higher volume of oil
and greater viscosity. For the next 300 miles I'd like to give the "seal
enhancement properties" of the ATF a chance to do their thing...
* Since the H/L was out, I took
the opportunity to check all bullet connections within. Sure enough, several
connections were in bad shape - at least two were down to one or two strands of corroded
copper wire.
* Resoldered all suspect bullets,
cleaning the contacts and packing the connections with dielectric silicone grease in the
process.
There is a noticeable improvement
in lighting - brighter burning bulbs. Rode around for about 20 to 30 miles (about
1.5 hours) with the headlight on without running the battery down. This might
indicate that the charging system is OK after all and that the earlier battery drain
problems were the result of bad connections within the H/L housing, but a complete
charging system test is in order regardless...
* Changed the tachometer cable;
installed another used one in better shape.
* Reversed the position of the
"O" ring in the tach drive pickup to address oil seepage in that area.
* Installed a used, but better than
original speedometer cable.
* Replaced the lower grommet in the
H/L housing. [If the original replacement is unavailable, use the Motormite "Help!
PCV System Grommet"; Part # 42317].
