Honda SuperHawk: |
CB72 |
CB77 |
CYP77 |
Cb77 |
Cycle & Number
of Cylinders |
4 cycle
2 cylinders |
4 cycle
2 cylinders |
4 cycle
2 cylinders |
Piston Displacement |
247 cc |
305 cc |
305 cc |
Bore x Stroke |
54 mm x 54 mm |
60 mm x 54 mm |
60 mm x 54 mm |
Compression Ratio |
9.5 : 1 |
9.5 : 1 |
9.5 : 1 |
Maximum HP |
24 ps
@ 9000 r.p.m. |
28.5 ps
@ 9000 r.p.m. |
28.5 ps
@ 9000 r.p.m. |
Spark Plug |
D8H |
D8H |
D8H |
Carburator (2 units) |
PW22 |
PW26 |
PW26 |
Lubrication System |
Wet sump: with a
gear-driven pump |
Clutch |
Wet:
multi-plates |
Transmission |
Forward 4-speed,
constant mesh |
Starter |
Electric starter &
Kick pedal |
Crankcase Oil Capacity |
1.2 liters |
1.2 liters |
1.2 liters |
Tire Size: (Front) |
2.75 - 18 |
2.75 - 18 |
3.25 - 17 |
(Rear) |
3.00 - 18 |
3.00 - 18 |
3.50 - 17 |
Fuel Tank Capacity |
14 liters |
Overall Length |
2,025 mm |
2,025 mm |
2,050 mm |
Overall Width |
615 mm |
615 mm |
830 mm |
Overall Height |
950 mm |
950 mm |
1,060 mm |
Wheel Base |
1,295 mm |
1,295 mm |
1,290 mm |
Ground Clearance |
140 mm |
125 mm |
Dry Weight |
153 kg |
159 kg |
269 kg |
Maximum Speed |
155 km/hr |
160 km/hr |
145 km/hr |
Fuel Consumption |
45 km/lit |
Stopping Distance |
16 meters, from the
speed of 50 km/hr |
