Advertisement: David Silver Spares, UK
Honda305 Marketplace
Honda SuperHawk Electronic Ignition: CB72, CB77, CP77, CYP77
FAQ: Reproduction Mufflers
spacer
Q. Are the CB72/77 silencers exact replicas?
Q. What are the manufacturing process highlights?
Q. Are the CB72/77 silencers easy to fit?
Q. Do I need to alter mounting methods?
Q. What about the removable baffles?
Q. What is the steel quality?
Q. What is the quality of chrome plating on these mufflers?
Q. Will they last?
Q. What models are these silencers available for?
Q. Where can these mufflers be purchased?
Q. How much do they cost?
Q. Can I return the silencer if it's not what I require?
Q
A. Yes, they are an authentic copy of OEM mufflers, designed to match the originals exactly.
Q
A.
  • All CB72/77 mufflers are made to original specifications
  • Manufacturing standards comply with ISO 9001
  • The CB72/77 Twin system is manufactured from mill certified, cold rolled sheet steel (specification CRS - SPCC - SD)
  • Seam welds adhere to welding classification AS 1554
  • Superior chrome coating covers even non-visible surfaces
  • The exceptional mirror quality finish has an acid copper base with duplex nickel covers; i.e., one semi-bright and one bright, and a chrome finish; the process is commonly known as Triple Chrome Plating
CB72/77 Reproduction Muffler/Silencer
Q
A. Yes, they bolt instantly into place, using existing mountings.
Q
A. No, there is no need to alter your original mountings.
Q
Q. What is the quality of steel in the reproduction mufflers?
A. The steel used to produce these mufflers is a Mill-Certified, CRS SPCC SD grade.
Q
A.
Exceptional. The chrome coating is total and of a mirror quality finish. The Triple Chrome Plating process encompasses an acid copper base with duplex nickel covers, beneath a final layer of chrome.
Q
Q. Will they last?
A.
This is a quality product designed to be durable. Seam welds adhere to the AS 1554 classification standard.
Q
A.
Presently, CB72, CB77 and CP77. Other models will be available soon.
Q
A. David Silver Spares, UK   [international shipments, daily]
Q
A.
129, each side, plus shipping and tax. (At the time of this writing, 1 = approximately US$ 1.44). Please email us for a delivery quote.
Available January, 2001.
Q
A. Yes, please contact us for the terms.
spacer
