Q.
A.
Can
I leave the ignition in the "on" position with the
motor not running? If yes, for how long?
[ Applies to Kits produced before
October, 2008 ]
Yes. ...here is the full story:
The heart
and brain of the Electronic Ignition system is the control
module, AKA the "black box" or "module." The
black box, as any electronic device generates heat. This heat
must be dissipated in order to maintain the control module within
a safe operating temperature range. The Electronic Ignition kits,
described here, dissipate the heat by radiating it through a heat
sink mounted on top of the control module. On a moving bike, the
airflow facilitates the exchange of heat between the heat sink
and the atmosphere. On a stationary bike, with the ignition on
and the motor not running, airflow is minimal and the amount of
time the ignition can remain in the "on" position is
limited.
The current installation instructions specify that the ignition
should not be left in the "on" position, with the engine
not running (power-on/engine-off), for more than one minute. Changes
to the transistors, heat sink, and potting since the original
development was completed have made the earlier one-minute limit
somewhat conservative. With this in mind, and in response to several
questions on this topic, new tests were run (March, 2003) to
determine how long it would be safe to leave the ignition in the
"on" state with the engine not running
(power-on/engine-off). The new test values apply to the Electronic
Ignition systems with the integral type of the module heat sink. If
your control module's heat sink is attached with a screw, these
modified values do not apply, however the early designs were
superceded rather early on in the production and the new values,
discussed here, apply to the majority of the units sold over the
past several years, as well as to those currently in production.
Please Note: In general, and regardless of whether your
bike has the original points-type ignition or not, leaving the power
on without starting the motor (power-on/engine-off) should be
avoided, if only to reduce the chance of overheating the coils, and
also to avoid the unnecessary battery drain.
The control module's self-heating can be more than
twice as high with the engine stopped as when it is running.
Furthermore, how much self-heating occurs is strongly dependent
on the ignition coil's primary resistance. A low resistance coil
(typically, a high-performance aftermarket coil) will lead to a
higher current draw and higher module temperatures. The typical
range of coil primary resistance is from about 5 ohms down to
about 3 ohms (the stock CB/CL 72/77 coils have about a 4.5 ohm
primary resistance). |
The
attached graph shows the results of three different tests
performed, on CB/CL 72/77 motors equipped with the Electronic
Ignition upgrade kits. The values are graphed on a time vs.
temperature chart: |
The
yellow line represents a running motor (power-on/motor-on), on a
stationary motorcycle, with stock coils. The blue line represents
a power-on/motor-off, with stock 4.5-ohm coils. The red line
represents a power-on/motor-off, with high performance 3.0-ohm
coils. Detailed explanations of the three tests follow: |
Yellow
Line: [Stock
Coils, Ignition "on" Motor "on"]
The straight
yellow line shows the “baseline” steady-state temperature of
the module’s heat-sink fins in 70° F, still air, in the test
lab, with a load of 1.22 amperes per coil, after nearly three
hours of operation. This would be typical of a RUNNING Super Hawk
or Scrambler engine with stock coils (4.5 ohms) and the battery
at 14.5 volts (that is, being charged).
Under the conditions
described above, the module temperature was stable at just under
99° F, feeling barely warm to the touch. With the addition of
even very modest airflow over the fins, the temperature would
drop much closer to the ambient air temperature, down to below 80°
F. (Bear in mind that in Phoenix, Arizona, in the summer, with
the air temperature at 115° F, the module would still run
anywhere from 7° to 20° warmer than the air temperature.
Depending on airflow, the corresponding fin temperatures might
range from 122° F to 135° F, still perfectly safe for
continuous operation and long life.)
Blue Line:
[Stock Coils,
Ignition "on" Motor "off"]
The blue line
shows the temperature rise of the module fins, over the course of
15 minutes, with a load of 2.45 amperes, per coil, starting at
about 73° F. The load of 2.45 amperes per coil would result from
having the ignition on with the engine not running, stock 4.5-ohm
Honda coils, and the battery terminal voltage at about 12.38
volts (as it would be under load, with the engine not running,
and therefore not charging). After 15 minutes, the fin
temperature reached 145° F, and the test was terminated. This
fin temperature, while just high enough to feel “hot” to a
prolonged touch of the hand, is still not hot enough to damage
the module, but it is getting there. From the look of the curve,
it appears that it would probably level off and stop getting any
hotter at around the 160° F to 165° F level (with the ambient
air at 70° F). While this would not damage the module, keep in
mind that the same test in Phoenix, AZ, in the summer, might
create fin temperatures exceeding 200° F, nearing the boiling
point of water; this would be too hot for reliability. In
summary: 15 minutes of module power-on with the engine stopped in
a cool ambient temperature would not be excessive, and 7 or 8
minutes in a hot ambient temperature would not be unreasonable,
using stock Honda 4.5 ohm coils. Note that one or both of the
coils will also be getting hot under these conditions, and they
may be less happy about the situation than the module, since
their power dissipation is 8 or 9 times as high.
Red Line:
[High Performance
Coils, Ignition "on" Motor "off"]
The graph’s
red line shows the module fin temperature over 5 minutes of
power-on/engine-off, with 3.5 amperes per coil - the equivalent of
a 12.38-volt battery terminal voltage and 3-ohm (high-performance)
ignition coils. In only 5 minutes, the high-current coils caused
the module fins to reach over 160° F, where the test was ended.
Note that the slope of the line was not even beginning to flatten
out at 5 minutes, indicating that the module would have gotten
very hot indeed. Again, if the module had started out at 115°F,
for example: in Phoenix, AZ, in the summer, it would have reached
about 200° F in only 1 or 2 minutes – again, too hot for
reliability. The module may survive one, or even a few trips to
that temperature, but then again, it may not. So, the rule for
low-resistance, high-performance coils is close to the original
conservative installation instructions guideline; 4 or 5 minutes
starting out near 70° F is permissible for power-on/engine-off
conditions in cool weather, and just 1 or 2 minutes in very
hot-weather conditions.
In summary: try to avoid leaving the ignition "on" when
the motor is "off" - this goes for any bike - and
instead, turn both on and take the bike out for a nice ride!
