- jleewebb
not bulletproof
So now you know you're not bulletproof...a valuable lesson for a young rider...or a geezer like me who sometimes feels 19 again when adrenaline kicks in...could have been lots worse, I'm sure. Best wishes for a speedy recovery. --Lee
'62 CB77. "It's a rider."
mike horvath
jensen
- Contact:
Hi Scott,
As personal damage appears mostly under the skin, so it is with motorcycles.
Be sure to measure and check lining of the front / rear wheel, check straightness of the forks (front and rear), check steering head for smooth turning. The frame of the CB's are not very strong, but easily to straighten out, forks also.
Thank you for the support everyone. The bike loosened up quite a bit in the fall. I believe the forks might have been ever so slightly as well as the front fender. Tightening everything back down might do the trick with a little bit of bending.
I'll have to get the fork covers that attach to the headlight re-powdercoated since the tangs that the light bolts to bend a slight crease right there. Nothing too big though.
Gonna pull some stuff off today with the help of friend who has two working arms ; )
jensen wrote:As personal damage appears mostly under the skin, so it is with motorcycles.
Be sure to measure and check lining of the front / rear wheel, check straightness of the forks (front and rear), check steering head for smooth turning. The frame of the CB's are not very strong, but easily to straighten out, forks also. Jensen
- h305 Moderator
Both times (the only times!) I dropped my CB77, at 16, were in similar lay-it-down situations such as yours, Scott. The only structural damage sustained by the bike was a twist in the fork legs, much like that of a bicycle; slackening off the legs' pinch bolts in the bottom yoke (triple-tree) and knocking the front wheel against a wall, using the handlebar, fixed the flaw in each case.
Hope the pain's subsiding!
FastFred hooked me up with a box of parts I've been dying to get ahold of for a great price. Been doing alot of stripping, painting, and polishing to get them back to their original condition.
Can't wait to replace previous owner's CL kickstart with the proper CB!
