carb o-ring no 16173-250-004
carb o-ring no 16173-250-004I have a 67 ca78 with the 305, needed an o-ring to attach the carb to the spacer, found one with this number, but its too small, diagram says its should be 24x2.4, but mine is at least 36 mm wide. so dd they change in the later years, new part no?
67 ca78 Dream
82 cb450 Nighthawk 05 kfx700 07 mule 97 vette Re: carb o-ring no 16173-250-004Just measure the one you have and buy a replacement from a generic bearing / seal supplier.
This is where I get mine. https://simplybearings.co.uk/shop/Produ ... index.html G '60 C77 '60 C72 '62 C72 Dream '63 CL72
