Which carb?Which carb?1964 CA77E engine ser # 102241 frame CA78-102223. I had 3 disassembled bikes 1963 CA72, 1964 CA77, 1966 CA77. One carb is square bowl without drain screw the other is round bowl with drain screw. Which carb should be on the 1964 CA77E? Thanks in advance. Plan on sending the correct one to LM for overhaul.
