honda305 Home honda305 Auctions honda305 Gallery honda305 Forum Electronic Ignition honda305 Forum honda305 Forum honda305 Forum honda305 Racing honda305 Literature
Auctions  Mailing List    Registry   Marketplace
honda305.com Forum - FULL SCREEN
  □ CLASSIFIED_ADS
  □ SEARCH_ADS
  □ MY_ADS
kicker shaft turns and turns and turns..
barnbiketom
Post by barnbiketom » Sun Apr 18, 2021 1:19 pm
welp the kick shaft coming out of the cases will crank the motor when turned counter clockwise...
BUT when trying to index everything to put together, the shaft turns and turns and turns clockwise...
The previous owner had probably changed he clutch cable and failed to put things back correctly, and ran it with the pawl engaged???
Question: can i run it?
electric start works fine.
Id like to ride this thing then in the winter tear into it.
I'll definitely drop the oil pump and screen and see whats in there...
I like stock...
A few modern mods...
But worst of all are those gawl dang PODS
barnbiketom
Re: kicker shaft turns and turns and turns..
Post by barnbiketom » Sat May 22, 2021 7:46 am
The kick stopper bolt, behind the clutch basket and the larger of the bolts that retains the shifting detent was loose and backed out almost touching the basket!!
Good news, but i also found a piece of a gear cotter in the sump. Engine is coming out and bottom coming off for inspection
I like stock...
