ca77 clutch
bluejean
ca77 clutch
Post by bluejean » Wed Aug 01, 2018 4:52 pm
1965 Honda ca77 installing clutch plates and friction disks. The first plate ( the thicker one) has a beveled edge goes facing in or out towards the friction plates? and when do I install the the wire clip that holds them in?
rrietman
Post by rrietman » Wed Aug 01, 2018 11:02 pm
bevel in. skip the wires.
Good luck
Randy
Re: ca77 clutch
Post by LOUD MOUSE » Fri Aug 10, 2018 5:55 pm
Not that it matters that HONDA installed that plate with the rounded side toward the case.
Ya can use it any way ya like as it contacts the same amount of area.
DO PUT THE WIRES IN!. ....................lm[
quote="bluejean"]1965 Honda ca77 installing clutch plates and friction disks. The first plate ( the thicker one) has a beveled edge goes facing in or out towards the friction plates? and when do I install the the wire clip that holds them in?[/quote]
