honda305 Home honda305 Auctions honda305 Gallery honda305 Forum Electronic Ignition honda305 Forum honda305 Forum honda305 Forum honda305 Racing honda305 Literature
Auctions  Mailing List    Registry   Marketplace
honda305.com Forum - FULL SCREEN
  □ CLASSIFIED_ADS
  □ SEARCH_ADS
  □ MY_ADS
1967 CL77 Rear Wheel Binding
quidger
Post by quidger » Tue Oct 19, 2021 10:31 am
I am restoring a CL77. Installing rear wheel.
Rear wheel has been relaced with new spokes and spins true on the the truing stand. New bearings. Axle appears to be straight.
When I install and tighten the axle nut with moderate torque the wheel is hard to turn. There's no way it would turn at all if I torqued it to spec of 142 foot lbs.
I took the wheel apart to see if there was anything obvious that would cause this but didn't see anything. I thought maybe the new bearings weren't seated properly and were protruding a bit but they were fine. I don't see how the brakes could be a factor.
Thanks for any input that you all may have to help me figure this out.
Incidentally, 142 foot lbs seems excessive.
Thanks
S90 / CB550 / CA 77 Dream 305 / Yamaha RT2 360
Tim Allman
Re: 1967 CL77 Rear Wheel Binding
Post by Tim Allman » Sat Oct 23, 2021 9:03 am
This forum is pretty much dead. Try posting on the Honda Twins forum.
https://www.hondatwins.net/forums
oldbikedude
Post by oldbikedude » Fri Nov 12, 2021 6:59 pm
is the center spacer between the bearings?
'67 Ca77 Dream
