Ca77 plug gapCa77 plug gapSirs, Looking for advice here, the only way I can get my CA77 to fire is gapping the plug to .35. I understand it should be .26 but will it do any damage at .35. Thanks
Re: Ca77 plug gapWell this site is not the one I remember, out of nearly 50 views to my question not one reply. is it maybe the batch of Spam we went through that has knocked the stuffing out of everyone.
Re: Ca77 plug gapOK. In violation of these words of wisdom......“It is better to keep one’s mouth shut and be thought a fool than to open it and remove all doubt.” .......
I would think something is off spec with the fuel mixture, coil resistance value, points gap, plug cap resistance etc, Frequently plug gaps and point gaps are spec'd as a range, so it's not normally critical that a specific reading be set for the engine to run. Do you have stock size OEM jets and stock float level values, coil resistance, and points gap? I would start with checking all tune up specs are correct 66 dream, 78 cb750k, 02fz1, 09 wing
Re: Ca77 plug gapThe lack of response may have been due to your use of .35 and .26, instead of .035 and .026. It would seem to be a coil, condenser, plug wire, or spark plug cap issue. Is it the same for both cylinders? But, you can't rule out carb or voltage issues.
Re: Ca77 plug gapThanks for the lighthearted correction cknight should have said .035, Did a test with multimeter and discovered no reading on secondary circuit. Anyways dug an original coil out of my spares that I didn't have much faith in but at least I had a reading. Treated the bike to a new set of plugs ( .026 ) and away she went. Although I havnt been able to give the bike a good run only a few hundred yards it does seem better performance.
But should things go pear shaped again I am seriously considering going with electronic ignition. Thanks to everyone who offered advice. Re: Ca77 plug gapCasamere....after re-reading my attempt to be self-deprecating, I now see how it could sound a bit condescending, so I apologize for that!
At any rate, the primary resistance of the coil should be greater than 3 ohms to function as well as stock. Some "replacement" coils are much less and that which causes increased current in the points circuit.......not good!.....especially if you happen to leave the ignition on while the points are closed. One I bought had only 1.6 ohm primary, so I was afraid to use it with out a ballast resistor, and just repaired the wires on my old one. I had an MSD ignition on on old truck which gave off a spark that looked like a lightening strike, and if I could find one for a motorcycle ignition I would be tempted to try it. 66 dream, 78 cb750k, 02fz1, 09 wing
