I need an external type speedo drive for a 61
Paul Strassmaier
Post by Paul Strassmaier » Thu Apr 16, 2015 12:13 pm
Anyone got one? It has the fingers that engage the plate on the hub...
CB72, CL72, CS72, CYP77
C71,JC57,D, 4E, Z50m
I'm workiarRe: I need an external type speedo drive for a 61
Post by LOUD MOUSE » Thu Apr 16, 2015 1:06 pm
I restoring a 61 and may have a spare used one.
I'll check tomorrow as I'm on my way to the San Antonio airport to pic up may son. ................lm
Paul Strassmaier wrote:Anyone got one? It has the fingers that engage the plate on the hub...
Paul Strassmaier
Post by Paul Strassmaier » Thu Apr 16, 2015 5:31 pm
Great, thanks
Post by LOUD MOUSE » Thu Apr 23, 2015 9:49 am
I finally had time to check on the speedo drive.
I have a used one with a good neoprene seal and it has a small amount of surface rust on the inside steel part.
I had cleaned it several years back so the rust.
It won't affect the operation.
The gears need grease which as I'm sure you know is inserted through the removable screw hole.
$60.00 plus $5.00 mail. ........................lm
Paul Strassmaier wrote:Great, thanks
Paul Strassmaier
Post by Paul Strassmaier » Thu Apr 23, 2015 11:19 am
That sounds about right, thanks. I'll send you a PM.
