Removal of steering lock CL72
KayPea
Post by KayPea » Mon May 13, 2019 2:47 pm
I need help, I got a 1962 CL72 and trying to get registered in Germany, must have a serviceable steering lock. Now my steering lock is seized solid, I need
1) Advice on how to remove old lock mechanism
2) Another serviceable unit.
3) Part number of the steering lock mechanism.
KayPee
OldScrambler
Post by OldScrambler » Tue May 14, 2019 10:06 am
Assuming the chrome cover is in place..............drill out the little screw twist while prying the thimble-like cover from the lock-holder casting. Then drill or pry the lock itself from the casting....there is a small internal pin that you will likely have to shear.
When that is accomplished I have a lock with key.............
BTW........a long-time friend tried to register his CL72 in Germany after moving from Australia. He was required to install turn-signals, a stronger (brighter) headlamp, and a metric speedo
KayPea
Steering lock 🔐
Post by KayPea » Tue May 14, 2019 12:34 pm
Good day to you
Thanx for reply, I have responded to your email address
