CB750 carbs on CB77
CB750 carbs on CB77Just curious if anyone had used the cb750 carbies on the cb77. I think Bill Silver mentioned in a post someplace that they offered a performance improvement .
Re: CB750 carbs on CB77The KO model is being used today.
It does require a mount with rubber for it to be installed. I sold a 5 speed CB77 which had the 750 carbs. I have a complete set (one missing bowl) and if the #3 carb has the choke lever changed it makes 2 sets for the CB/CL72/77 engines. .........lm..................lm
Cheers Old scrambler
Like these http://www.ebay.com/itm/HONDA-OEM-CARB- ... 1699960688 I am wondering how much difference these engines when standard will perform with 28 mm carbs
I'd say 26 to 28 is no big deal as you are using carbs designed for a 152 piston area and the 350 is a 175 piston area.23 difference.
That's about the size of a .40 model engine. ...............lm
