CB72 Neutral switch vs CA77 neutral switch
Greggie-e
Post by Greggie-e » Thu Oct 10, 2019 10:14 pm
Hey I need a neutral switch for my CB72, this has a code of 35750-259-000
https://www.cmsnl.com/honda-cb72-hawk-6 ... Z_xEUYzaUk
It looks the same as a neutral switch from a CA77, but this has a code of 35750-268-000
https://www.cmsnl.com/honda-ca77-1960-1 ... Z_xsEYzaUk
Does anyone know if there is a difference or are they interchangeable?
Cheers,
Greg
DJM
Neutral switch.
Post by DJM » Fri Oct 11, 2019 8:48 am
I'm sure the switches will be the same as all of the gear selection parts, drum, forks and mechanism are interchangeable between the CA, CB and CL models, only the actual gears and shafts being different. No reason at all for the switches to be different.
Re: Neutral switch.
Post by LOUD MOUSE » Fri Oct 11, 2019 12:26 pm
They are the same. ............lm
DJM wrote:I'm sure the switches will be the same as all of the gear selection parts, drum, forks and mechanism are interchangeable between the CA, CB and CL models, only the actual gears and shafts being different. No reason at all for the switches to be different.
