![Image](https://i.postimg.cc/R0fqq41v/P1080161.jpg)
Also started dismantling the rear shocks. For the CB77 shocks I was able to compress them enough by hand to remove the collets but either I am getting weaker (likely) or the spring is stronger on the CL as I had to make a tool to compress. Metal would have been more elegant/durable but with the tools and materials I had it was much easier to use some plywood and it worked well.
![Image](https://i.postimg.cc/cLvvyQrg/P1080162.jpg)
![Image](https://i.postimg.cc/dtHhxWtc/P1080164.jpg)
There is some damping in the shocks and no obvious oil leaks but not sure if the damping is good enough. The covers also need quite a bit of work. I will have to look into seal availability especially as I do not have the skill or equipment to produce new seal holders as I think G-man did on his shock rebuilds.
Interestingly the shocks had been mounted using 7mm bolts in 8mm bushes!
Greg
