valve guide Remmoval
thepunisher2007
Post by thepunisher2007 » Tue Feb 19, 2019 7:58 am
ill try the oven trick then next. is there any need to have the head skimmed after or is there no chance of warping in from the heat?
AlanW
Post by AlanW » Tue Feb 19, 2019 8:09 am
Never had distortion problems but it always pays to check the flatness.
Al.
thepunisher2007
Post by thepunisher2007 » Wed Feb 20, 2019 4:27 am
so cooking time wise how long is it best to leave it baking for.
DJM
Cooking time
Post by DJM » Wed Feb 20, 2019 5:09 am
Provided that your wife's oven thermostat is working you can't overcook it, it will only get up to the temperature of the oven regardless of how long you leave it in there.
A cylinder head is a BIG lump of metal which will take a long while to heat right through.
I would say a minimum of 2 - 3 hours maybe longer and DON'T Forget some GOOD oven gloves, it would be a shame to drop it!
AlanW
valve guides
Post by AlanW » Wed Feb 20, 2019 4:32 pm
Never left one more than 1/2 an hour once the oven is up to temp and it has always worked,
as Dennis says use good gloves you really don't want to drop it, that's why I use welding ones.
Al.
thepunisher2007
Post by thepunisher2007 » Sat Feb 23, 2019 7:15 am
ok so it’s in the oven now i’ll left you know how i get on
thepunisher2007
Post by thepunisher2007 » Sat Feb 23, 2019 7:21 am
thank you so much for all your help i’m happy to report the guides are out. would you recommend heating the new ones in
