CL77 305 Cam Chain Tensioner Roller
gbyoung2
Post by gbyoung2 » Sat Feb 15, 2020 12:20 pm
If anyone happens to have a (CL77) 305 cam chain tensioner out, or one laying about, would you mind measuring the diameter of the roller?
May come a time when I will want to turn a new one and I wanted to see if the material I have now has a large enough diameter.
Thank you.
Re: CL77 305 Cam Chain Tensioner Roller
Post by LOUD MOUSE » Sat Feb 15, 2020 8:07 pm
HONDA issued 2 diameter neoprene wheels.
However the FIRST issue has the Set Screw to the Left.
Next the screw was to the right.
The Wheel is 1.6 in.+-.
The best I can say is they issued a smaller diameter wheel at some time with the screw to the right. .............lm
gbyoung2
Post by gbyoung2 » Sun Feb 16, 2020 7:45 am
Thank you.
Believe we're good. A friend has my length of Delrin rod I turned some elliptical rollers from, and I think it's close to that. He's out of town right now, but will see when he gets back.
Post by G-Man » Mon Feb 17, 2020 9:15 am
You could try replacing it with a Kawasaki one, like this.....
Simialr to the Capellini modification but a little more cost-effective.....
Post by Seadog » Mon Feb 17, 2020 10:26 am
If that’s the Kawasaki cam chain idler sprocket, part number 12057-002, for the Z1, KZ900 & KZ1000 (thru 1980), the price (new) is upwards of $170 and you’d still need the other parts. A complete Cappellini kit costs $133. The Kawasaki option is great if you can find a good used one though.
gbyoung2
Post by gbyoung2 » Mon Feb 17, 2020 12:55 pm
Never heard of the Cappellini kit (I don't get out much), but looks pricey, as does the Kaw Z1 toothed sprocket. The Z1 12055-002 lower roller (guide) from the same bike at ~$18 actually looks a little more promising.
I could probably turn one out of a $1.00 (or less) slug of Delrin...... but do appreciate the suggestions.
I really hope I don't need to worry about this for awhile, but good to know there are possibilities out there.
Post by G-Man » Sat Apr 25, 2020 1:22 am
The Kawasaki sprocket is very durable and they can be found on eBay for less than $50, often you get a couple of them for that.
