Carburetor stuck on full throttle - CA77
Michael Stoic
Post by Michael Stoic » Mon Aug 21, 2023 8:31 am
[ Posting for newly registered user - Msmall1154 ]
Carb at full throttle on 63 Honda Dream after reassembled
I took my carb apart on my 63 Honda 305 dream CA77. When put back together it is stuck at full throttle. What did I screw up?
Michael Small
deuce_7
Re: Carburetor stuck on full throttle - CA77
Post by deuce_7 » Mon Aug 21, 2023 8:30 pm
Here are a couple of older posts from the Honda 305 forum that can be a good place to start:
http://www.honda305.com/forums/viewtopi ... a3d#p95767
viewtopic.php?t=36
Let us know what you find out,
1967 CL77 305 Scrambler
Muddy
Post by Muddy » Tue Aug 22, 2023 3:49 am
If I remember correctly, it is easy to have the throttle slide rotated around the wrong way (about 180 degrees). This makes the throttle slide sit much higher than the idle screw and results in high revs. You should be able to tell by the amount of travel in the twist of the throttle.
Thanks.
Regards
Muddy
'64 C72
'63 C72
Tim Allman
Post by Tim Allman » Tue Aug 22, 2023 4:50 pm
I once had a throttle slide stick because the nuts on the mounting studs were unevenly tightened. Apparently this can warp the carb body. You could loosen the nuts and see what happens when you turn the throttle.
Michael Stoic
Post by Michael Stoic » Fri Aug 25, 2023 7:24 pm
I've done both, at least once, when working on my '64 CP77 - what Muddy describes in his post and Tim in his.
__
Michael
