lurching in gear
I-man
Post by I-man » Sat Nov 07, 2009 5:11 pm
update. i took the clutch cover off and then took the clutch apart. the the plates were stuck together but came apart with some prying. I have a few questions ya'll might be able to help me with. Should the metal plates separate from the fiber ones? also, does the last one come out? it doesn't seem stuck, just a little bound up. should I get after it and make it come out? also, what should i use to clean the plates before oiling them? thanks
Dgormley
Clutch
Post by Dgormley » Sat Nov 07, 2009 6:25 pm
I-man, I just wiped mine off with rags. Check for flatness(I used a piece of plate glass) and measure your friction discs, specs are in the manual. Yes the last plate does come out and I think it might be thicker...............................D
I-man
Post by I-man » Sun Nov 08, 2009 7:01 am
just read in bill silvers manual 'later five plate clutch plates featured friction material bonded to a metal backing' so I guess it's likely that the metal ones don't separate from the friction ones. interesting. anyone know the torque setting for the four bolts that hold the clutch in?
I-man
Post by I-man » Sun Nov 08, 2009 9:47 am
i cleaned the plates and put it back together and adjusted the cable as recommended but it still won't roll in gear with the clutch engaged. I didn't put the cover back on so when I pull in the clutch i can see the plates expanding, but still no joy. some points of interest-I discovered that the metal plates do separate from the fiber ones. everything seemed to be in good shape. i couldn't get the last plate out, but i could pry it enough to tell that it wasn't stuck, just bound up in the basket. I've adjusted the cable adjustment screws to the limit at the clutch lever and there is about an inch and a quarter of threads showing on the adjusting screw where the cable goes into the housing. Help, please.
Dgormley
Clutch
Post by Dgormley » Sun Nov 08, 2009 10:08 am
I-man, Ball bearing in the clutch lifter piece?......................D
mike69
lurching
Post by mike69 » Sun Nov 08, 2009 10:44 am
The last plate may be held in place by a very thin wire.
These clutches are difficulut to adjust correctly.
I suggest buying a repair manual and follow the instuctions,
or hopefully some can print instuctions here.
66 Dream
78 Goldwing
I-man
Post by I-man » Sun Nov 08, 2009 11:01 am
it does seem like i'm missing something on the adjustment. i did it the way I discribed it in my first post in this thread. maybe someone with more experience will read what I wrote and let me know if that seems correct. has to the ball bearing, could someone walk me through checking that? I've got bill silvers manual, but I learn best with pictures, and frankly much of it is over my head.
