Clutch Plate Interchangeability
brewsky
Post by brewsky » Sat Feb 13, 2010 6:44 pm
The friction plates from my 66 ca77 measure 3.8mm (5 plates with 2 wires) and I need to purchase new ones.
Will the same thickness plates for CB or CL models work?
TIA
Re: Clutch Plate Interchangeability
Post by LOUD MOUSE » Sat Feb 13, 2010 8:19 pm
What is the core of your plates?. ................lm
brewsky wrote:The friction plates from my 66 ca77 measure 3.8mm (5 plates with 2 wires) and I need to purchase new ones.
TIA
brewsky
Post by brewsky » Sat Feb 13, 2010 9:25 pm
They are all fiber.
I cleaned them in gas and was going to re-use them, but I noticed some flaking when rubbed, so I figured they should be replaced.
The basket has 5 fiber, 4 thin and 1 thick steel plates, with 2 wire separators, and has a "5" stamped inside.
The springs measure 1.35" with no white marking on the ends... maybe the ("next to last") edition?
The fibers measure 3.8 mm with some wear, so i'm guessing they were 4mm originally?
THANKS for your help
Post by LOUD MOUSE » Sat Feb 13, 2010 9:42 pm
I can supply a set of the aluminum core nos or perfect used.
Please PM me if interested. ................lm
brewsky wrote:They are all fiber.
brewsky
Post by brewsky » Sat Feb 13, 2010 11:08 pm
PM Sent
CLUTCH
Post by LOUD MOUSE » Sun Feb 14, 2010 8:28 am
Have it.
Will call. ..........lm
brewsky wrote:PM Sent
brewsky
Post by brewsky » Mon Mar 01, 2010 8:07 pm
Got re-furbished friction plates today from Loud Mouse and they look much better than what I removed!
The metal core friction plates have much more contact area than the all fiber version.
I had tried cleaning the old all fiber plates but they started flaking so I was afraid to use them.
Pics showing the difference below:
