are kenig hi comp.pistons any good ??
G-GAURD
Post by G-GAURD » Fri Jul 30, 2010 8:07 am
are these pistons any good and will i have to make them fit my ca77 if there for a cb77?
teazer
Post by teazer » Fri Jul 30, 2010 8:38 am
If they are the high compression pistons, I'd steer clear of them unless you are prepared to machine the crowns and check all the clearances at least twice to be 110% sure that they are OK.
Re: are kenig hi comp.pistons any good ??
Post by LOUD MOUSE » Fri Jul 30, 2010 11:28 am
If you use CB77 pistons in a CA77 engine you will decrease the compression which will lower the power some. ...........lm
G-GAURD wrote:are these pistons any good and will i have to make them fit my ca77 if there for a cb77?
teazer
Post by teazer » Fri Jul 30, 2010 1:33 pm
Ed,
I have very little experience with Dream motors. Are the Dream pistons much different to the Superhawk? I never checked, but always assumed that the CB pistons would have taller domes for higher CR.
Sounds like that may not be the case.
Post by LOUD MOUSE » Fri Jul 30, 2010 2:25 pm
After HONDA lowered the compression (lower dome) early in production the domes of the CA77 and CB/CL77 pistons have the same height from the wrist pin.
The visible difference is the CB/CL77 piston is machined around the top edge where the CA77 is a full Hemi (dome) on the top. ............lm
teazer wrote:Ed,
teazer
Post by teazer » Sat Jul 31, 2010 1:00 am
Thanks for the explanation.
Post by LOUD MOUSE » Sat Jul 31, 2010 7:19 am
Ya welcome.
If ya want a cheap small increase in power the CA77 piston is a way to go. ..........lm
teazer wrote:Thanks for the explanation.
