For the home plating specialist
zoom
Post by zoom » Thu Dec 02, 2010 10:08 pm
For those of you that have zinc or nickel plated at home, what have you used for a power source?
Any pics of the set up?
Jay
Wilf
Post by Wilf » Thu Dec 02, 2010 11:07 pm
Jay,
You may want to read the thread, "restoring old bolts" in the Badges, Seat... section.
Wilf
cyclon36
Post by cyclon36 » Thu Dec 02, 2010 11:16 pm
I've thought about doing some home plating for the smaller items. This site has everything for the DIY plate job: http://www.caswellplating.com/kits/index.html
conbs
Electroplating
Post by conbs » Thu Dec 02, 2010 11:57 pm
I have been looking at this kit from Eastwood. Power supply is 2 D batteries.
http://www.eastwood.com/ew-electroplati ... -zinc.html
Wilf
Post by Wilf » Fri Dec 03, 2010 12:53 am
Eastwood, Caswell.....whatever retail.....I like DIY.
Wilf
Snakeoil
Post by Snakeoil » Fri Dec 03, 2010 11:50 am
Wilf,
I just read your instructions on how to zinc plate at home. Many thanks for sharing this. I suspect I'll be giving this a try over the weekend.
This is one of the best Christmas presents I've ever received.
Best regards,
Rob
conbs
Chrome Plating
Post by conbs » Fri Dec 03, 2010 12:31 pm
A little over a year ago I was looking in the Metalworking section of ebay and a guy had a brochure that told how to DIY chrome plating (it also shows how to copper and nickel plate) . His brochure was pretty cheap so I bought one. His method uses sulfuric acid from car batteries and a battery charger 5-10 amps.
I think you have to be some what well versed on the science involved to follow his instructions, but I do think you you could actually chrome plate in your garage (or even your kitchen if you have an understanding wife.....Nah, probably not). I thought about trying it, but haven't had the need just yet, so I can't say I have the courage.
He lists Caswell as a supplier, but his method seems like it would be a LOT cheaper than their kits.
His company is YSUUSY Publishing in Tiffin Ohio.
I did not check out whether it would be leagl to do this kind of plating and even if it is legal in Idaho, there may be legal prohibition in other states or there may be local regulation. At a minimum you would be dealing with chemicals that require legal disposal. But, if you are the adventurous sort.......
One thing the guy stresses. NEVER pour water into acid. Only pour acid into water. I learned that the hard way in a college chemistry course. Luckily it was only a small test tube, but the reaction was immediate and violent. The point is, before taking on something like this a person would want to make sure and study everything in the brochure (several times) and probably do a good bit of additional study as well. But, it is not impossible, you would just want to be very careful.
