Just wondering if anyone on here does there own aluminum buffing? I picked up a couple of buffing disc's and some compound and tried a small part this morning and I'm very impressed with the look. I guess the more time you spend on the part the better it looks.
I'll wash each part down after and clear coat them.
Buffing aluminum?
Well today I removed the guards and grinding stones from my one hp 10 inch grinder and added two new buffing disc's.
I just took five minutes and did a small part of a rear shock. As you can see by the picture the parts were pretty ugly looking. I sanded the clear off with some fine emery cloth and then applied only two parts of the compound and it came out like this and It's not cleared yet. If I spent more time on it I'm sure it would look like chrome. I'm starting my new rebuild/restore Cub project this week so I wanted to do a test on the buffing and so far I like it. I attached a few pics for all to see. Paul
- Contact:
I started doing my own polishing years ago on a small bench grinder just because I couldn't afford to pay anyone to do it. Like you, I discovered that it is really not that difficult to turn ugly parts into beauties.
Oilleak
http://www.oilleak.net
Those who give up liberty for the sake of security deserve neither liberty nor security.
--- Ben Franklin
--- Ben Franklin
aluminum buffing
Which of the rough compounds do you use?
Mike
Mike
Mike I use just the black first and then the white one and do this because I only have two buffing wheels and you shouldn't use different compounds of one buffing wheel.
I get the parts almost as nice as actual chrome now that I'm use to doing it but the only thing I found about the actual buffing that I don't like is the mess it makes around the shop. I now have "Dust Bunnies" all over the place from the buffing wheels so from now on I'll be buffing outside. Getting the "Dust Bunnies" cleaned up is tough because there everywhere and I had to clean it because I paint in my shop and didn't want them getting into my paint work. Maybe it's just the type off buffing wheel I use. Anyone else run into this problem? Paul
This is the first bike I've buffed everything on and I'm happy with it!
