The parts book shows one red (positive lead) wire to the battery and the ground on the left side attaching to the frame. My bike has 2 red wires. The larger one is black with the red end coming from the starter magnetic switch and the thinner one is a red cloth wire with white markings and a red end coming from the rectifier (this is the one with the fuse). Has anyone seen this configuration and can you verify that both of these go to the positive post?
Thanks,
Mike
Battery lead question
Re: Battery lead question
The wires are installed correctly. .............lm
mjmudd wrote:The parts book shows one red (positive lead) wire to the battery and the ground on the left side attaching to the frame. My bike has 2 red wires. The larger one is black with the red end coming from the starter magnetic switch and the thinner one is a red cloth wire with white markings and a red end coming from the rectifier (this is the one with the fuse). Has anyone seen this configuration and can you verify that both of these go to the positive post?
Thanks,
Mike
Thanks for the quick responses!
Mike
Mike
