My Diamond is still rough
barnbiketom
Post by barnbiketom » Wed Feb 22, 2017 11:30 am
pemdoc65 wrote:Classic Honda Restoration sells replacement sleeves. They are easy to change out, but they need to be bored to size after installation. I heated my cylinders up in the oven (when my wife wasn't home) and they dropped right out. I put the new sleeve in the freezer, and it dropped into the warm block without much force.
10-4 about the wife. mine would know in a split second lolol.. she just knows me too well...
barnbiketom
today's observations... less than .003 clearance but..
Post by barnbiketom » Wed Feb 22, 2017 11:32 am
the remaining 3 circlips are oriented in all different positions. one the gap is up, one the gap is right, one is left... NOt GOOD.. supposed to be down ? right???
there appear to be TWO different sets of rings.
on the RT side, the blown side, only one ring has a marking.. the second ring ...it has a tiny "N" and a TINY step on the bottom of the ring..
the left side, no rings have markings but the middle ring has a much different profile than the one on the right.. a much bigger step in the bottom side...and it was stuck from varnish/gookum.
heres some pics of the piston the clip came out of...it does have a circlip escape pathnow that i soda blasted off the varnish!! , I can barely catch my fingernail on it!!
IMG_20170222_100550 (1).jpg (84.49 KiB) Viewed 2661 times
barnbiketom
nother
Post by barnbiketom » Wed Feb 22, 2017 3:23 pm
i soda blasted this one . grooves all cleaned up. I don't think it did too much damage??
Re: today's observations... less than .003 clearance but..
Post by LOUD MOUSE » Wed Feb 22, 2017 3:46 pm
Clips only need to "NOT HAVE THE OPEN AT THE DIMPLE". ..............lm
barnbiketom wrote:the remaining 3 circlips are oriented in all different positions. one the gap is up, one the gap is right, one is left... NOt GOOD.. supposed to be down ? right???
barnbiketom
Post by barnbiketom » Wed Feb 22, 2017 4:11 pm
No dimple is simple
Jims65CA77
Post by Jims65CA77 » Thu Feb 23, 2017 8:55 am
I didn't realize that sleeves fell out when heated. I "thought" that they had to be pressed in.
Jim
Post by G-Man » Fri Feb 24, 2017 12:42 pm
I just heat the barrel up with it inverted on blocks. The liners just drop out. Reverse is also true. Just heat up and they drop in. The machine shop I use recommends that you push them down with a press after the barrel has cooled.
