Questions about jets and excess oil...
Snakeoil
Post by Snakeoil » Wed Apr 06, 2011 8:23 am
MBellRacing wrote:Thanks, since they were only a few euro, I ordered them. None of the part numbers match the ones I found for the original needle for here in the US, figure they'd at least be an interesting experiment.
I too found a "conversion guide" to find a modern Keihin needle that is closest to older models. Anybody have the numbers off their stock set?
Can you share that guide with us here?
thanks,
Rob
brewsky
Post by brewsky » Wed Apr 06, 2011 11:07 am
Here's a comparison of the Keyster and Keihin needles for the CA77 (with needle numbers):
The only difference I can detect is the width of the circlip slots.
MBellRacing
Post by MBellRacing » Wed Apr 06, 2011 1:35 pm
Brewsky,
I saw the same thing when I looked at my Keyster needle versus the originals. It seems the fallback excuse for my bike's poor running is the Keyster needle and slow jet. I might agree with the latter. I wish I could find my originals.
Look here, only just scanned over the info and haven't seen the original numbers to see if there is a close relative to our CB77 needle.
http://www.motorcyclecarbs.com/KEIHIN_N ... __W252.cfm
teazer
Post by teazer » Wed Apr 06, 2011 11:41 pm
If the diameter is identical at 5mm intervals all the way from top to tip, then they are the same. Keyster needles are often quite a bit different at the tip or the root and they need to be absolutely thy same
Very small difference in diameter can make a huge difference to performance.
brewsky
Post by brewsky » Thu Apr 07, 2011 4:30 am
MBellRacing wrote:Brewsky,
Notice the needles I posted are for CA77, I believe CB and CL are different part numbers.
I haven't been able to find anything in the charts or diagrams to even match the same overall length.
Also, the conversion chart assumes a 6 digit OEM mark, and the CA needle only has 5
MBellRacing
Post by MBellRacing » Thu Apr 07, 2011 8:09 am
Yeah, after looking at that more, I realized there's nothing close to what we have but hoped they had more sections. My brother's CB175 has a similar problem with his Keyster needles versus stock. He can just hold them next to each other and notice the differences!
Snakeoil
Post by Snakeoil » Fri Apr 15, 2011 5:54 pm
brewsky wrote:Here's a comparison of the Keyster and Keihin needles for the CA77 (with needle numbers):
Brewsky,
Thanks again for posting those pics. Today I tried to solve a problem and I was afraid I had a pair of Keyster needles in my carbs. But based on your pics, they are Keihin needles. Circlip slot width and the steps just above the straight section match what I have.
No numbers on mine, though. Bike is a '67 CL77.
regards,
Rob
