When I bought my 66 CL77 the speedometer was whining and making a scraping noise while the needle was doing back flips like a schoolgirl. I found one on fleabay listed as a “working” used one with 6925 miles to replace the original, now we take a deep breath and are all smiles until last week when the replacement starts doing exactly like the original.
Sunday I “pm” LM for his sage advice and yesterday FedEx’ed both to Preston at Foreign Speedo, Inc. in San Diego for repair and service. I should hear back from Preston in a few days with his diagnosis and cost estimate for repair.
I have seen several post on this subject and since we all have 40 something year old speedometers I will be back with detailed results as the process continues. G
Speedometer Repair
Speedometer Repair
65 CA77 Dream
66 CL77 Scrambler
69 Triumph TR6
66 CL77 Scrambler
69 Triumph TR6
Spar, I have not heard back from the folks at Foreign Speedo as of this morning. I think they are waiting until they have them apart to offer their suggestions on repair. I know they were delivered Thursday but I do not know how busy they are and when mine will "come to the top." I will post as soon as I hear from them and let everyone know their diagnosis and price of repair. I am confident they are in the right hands for the task. GSpargett wrote:Did you ever find a solution to your speedometer problem? Mine just started to the very same thing. Jumping all over 8,000-9,000rpm as the idle was wobbling.
-Scott-
65 CA77 Dream
66 CL77 Scrambler
69 Triumph TR6
66 CL77 Scrambler
69 Triumph TR6
Gun both of the CL77 speedos I have are reverse drive. I used a drill to test them and they will do nothing in forward but in reverse they were fine until somewhere between 10 and 20 the needle goes nuts. One company (Overseas Speedometer) stated "I cannot help you, but the whining noise is usually a result of a lack of lubrication." They would not work on Nippon Seiki's. More to come.....
65 CA77 Dream
66 CL77 Scrambler
69 Triumph TR6
66 CL77 Scrambler
69 Triumph TR6
- h305 Moderator
The usual problem with speedo (& tacho) heads is ageing bearings. Mine (CB opposed) suffered the same whine and windscreen-wiper-needle-syndrome, oddly enough each within a couple of days of the other. It's aparently due to the needlepoint bearings and input shaft bushings drying out, falling out of tolerance and creating a hi-frequency 'shudder'; this causes the spinning magnet's linearity to become unstable. It seems to be, according to a VJMCUK contact, quite common in older Jap instruments. Once repaired the problem rarely re-occurs. It requires no more than (expert) opening up, servicing, adjustment and calibration. Don't write it off until it's been condemned by one of the service companies mentioned here.
