Case repair
Geoff Hastings
Case repair
Post by Geoff Hastings » Mon Mar 18, 2019 1:13 pm
As I had a bit of spare time I thought I'd try and repair a rather knocked about oil spinner cover. I used lumiweld, a low temperature ally repair. Using only a propane blow torch I ran into the damaged areas some of the Lumiweld, I then filed the surplus off and then wet and dry till level and then buffed it up. It's sort of OK, the Lumiweld is a slightly different shade so is visable, particularly the large area but the digs and scrapes look fine. The pictures are on flicker https://www.flickr.com/photos/148854602 ... res/A356Y8
Muddy
Post by Muddy » Mon Mar 18, 2019 3:04 pm
Nice job. It is great to find out these tips and products that work.
'64 C72
'62 C72
Tim Allman
Post by Tim Allman » Mon Mar 18, 2019 6:13 pm
Looks good. I have been thinking of doing the same thing as my oil filter cover also shows signs of riding my bike sideways. I think I'll do it.
BTW, Lumiweld is not the only supplier of this product. Bernzomatic sells the same thing (zinc with about 10% aluminium) and it can be found next to their propane torches. Maybe others sell it as well.
Geoff Hastings
Post by Geoff Hastings » Tue Mar 19, 2019 3:25 am
Quite right Tim,
I've seen similar products advertised, the main thing is to make sure the damaged area is cleaned properly and that the rod melts in contact with the case and not just drip it on to the case.
OldStan
Post by OldStan » Tue Mar 19, 2019 10:25 pm
Harbor freight sells it as well. I 've used it to repair holes in CL alternator covers. Like was said, slight difference in color, but beats a hole or bad crack, especially since the part is hard to come by. Also repaired some valve cap hex heads as well, which were a little tricky.
63 CA78
Post by Seadog » Wed Mar 20, 2019 9:45 am
I’ve tried using Alumiweld, but never seem able to get the part to be repaired hot enough, even using mapp gas.
Geoff Hastings
Post by Geoff Hastings » Wed Mar 20, 2019 2:14 pm
Mapp Gas should provide enough heat, I repaired the right hand case that was missing a lug. When I clamped it I made sure I insulated the case from the vice so the heat didn't soak away. Obviously the thinner parts are easier to get up to temperature but it's important to get to good clean metal, oxidised aluminium has a higher melting point and increases the risk of melting the item being repaired.
