weird clutch found in cb77 BTE
thumper2146
Post by thumper2146 » Fri Nov 14, 2008 5:50 pm
ok i take the clutch apart and I find the clutch has about a 3 mm spacer and it says on it
BTE HUNTINGTON BEACH CALIF. anyone ever hear of it also it only had 4 steel plates and 5 fiber ones.
Re: weird clutch found in cb77 BTE
Post by LOUD MOUSE » Fri Nov 14, 2008 7:28 pm
You have a BARNET CLUTCH and if you look at that part you will see it is warped and not flat to the plates. It's magnesium and isn't good after all these years. I replace them with OEM HONDA parts because about 1966 HONDA made clutch disc which in my opinion and experience are much better. '''''''''''''lm
thumper2146 wrote:ok i take the clutch apart and I find the clutch has about a 3 mm spacer and it says on it
RIDE IT DON'T HIDE IT!
thumper2146
thank you very much for the info
Post by thumper2146 » Fri Nov 14, 2008 8:49 pm
yes it does look warped . thank you Sir
james
