What year ?
What year ?
Hi guy's and gals
I finally got the frame and engine no. of my CB77 , and I wonder what year it is, If im correct it's from '67 , but I better ask the pro's around here.
Well, here they are :
Frame No. : CB77-1048027
Engine No. : CB77E-1048055
Im im correct the numbers of the engine and frame almost never match, so it's probably the original engine, correct ?
Thanks !
Today I prepped the frame, cleaned it and all, tomorrow the assembly starts and ill make a new topic where you guys can follow my progress.
Thanks !
Bonjour, Bonjour
Bill Silver's book give's those numbers as '64 to '67 but it's near the end - 1056494 so it could be '67. Check the white tag on the wiring harness and this gives the date of manufacture of the wire harness which will be earlier than date of registration.
Have fun
Have fun
Thanks, but the white tag doesn't show a date like it supposed to do, only a number.
I also did found a number 67 under the big alluminium piece where the steer is mounted on. (ja, don't know the name)
Under the number, or on the other side of the tag ?
There is absolutly nothing to see, ive tried to look al different angles, also in different light, but really nothing.
But now that I know where the date should be, I try to look again, but there is little chance that I spot it.
Anyway, thanks for the advise.
