Was $60.00 each. .................lm
G-Man wrote:DJM
I think you posted to the wrong part of the thread but yes - you are correct. Using the parent metal for the filler, the only option is to use conventional aluminium welding with a TiG or Oxyacetylene set.
DJM wrote:Not sure how that would work; I think the whole point of these kits is that the welding rod (actually it's solder) melts at a much lower temperature than the parts you're trying to repair.
If you made the rod from the same material as the parts that wouldn't happen, the donor rod wouldn't melt until it reached the same temperature as the components when the whole lot would go very quickly from a solid to a liquid state, there's a word for that critical point, I think s**t is the word I've heard used!
