Steve,
Thanks. What I was trying to do, as much as anything, was to demystify the whole blue smoke thing.
Electrics can be very daunting and it all looks like some sort of black magic, but if it is approached slowly and methodically, it's really quite simple (as you know).
tail light
Usually it's simply Battery to Ground. ........lm
teazer wrote:Steve,
- h305 Moderator
Diagram's erroneous 'meter lamp to headlamp dimmer link wire' corrected here.48lesco wrote:Hey Arch - Use the color wiring diagram from e3steve at the link below. It corrects the error in the Honda version at the ignition switch. Check your ignition switch connections carefully, and also in the headlight bucket.
http://www.honda305.com/forums/download.php?id=2424
