Posted: Thu Mar 14, 2013 2:20 pm
jensey wrote:Hi,
Engine is a '61, can you take a picture of the engine number ?
https://www.honda305.com/forum/
jensey wrote:Hi,
Not really a bonus for your project. Honda discontinued the breather tower early on. What may be a bonus about it being a 1961 motor is someone may be able to use it for a 1961 restoration.captain awesome wrote:
I assume the breather tower is a bonus?
If I stumble across a CL or CB motor, that may be a possibility.Hoosier Tom wrote:Not really a bonus for your project. Honda discontinued the breather tower early on. What may be a bonus about it being a 1961 motor is someone may be able to use it for a 1961 restoration.captain awesome wrote:
HT
It sounds like I need to look for a different motor to use and let someone have this for a restoration.jensey wrote:Hi,
Thanks for the picture. Yes, an early CA77 1961 engine.
If you use the engine, be aware that it has no primary chain tensioner, an old type no good clutch, and gears with pitting issue's. An 8 hole cylinder without the extra oil way, and it uses 10 mm spark plugs (instead of 12 mm). But the casting is a little thicker
