How to check coil on a 305 dream
rrietman
Post by rrietman » Wed Jun 29, 2016 12:08 am
I wonder about that coil. dream coils should have screw on wire connectors (early), or wires potted directly into the case(late).
Good luck
Randy
revlover
Post by revlover » Wed Jun 29, 2016 2:13 pm
Also.. don't forget to check the condenser that Honda hid on top of the head.
Nick
Post by Nick » Wed Jun 29, 2016 9:17 pm
If the points are sparking when the engine is running, that can indicate a bad condenser.
Old high tension leads/plug caps can cause misfire/poor running. Replace leads with new. Replace plug caps.
If you suspect that the high tension leads are leaking, put fuel line around each coil wire for better insulation.
Are the points' mating surfaces clean and smooth? If not, file/sand smooth. Check timing using strobe light (just buy one, they're cheap and it's the only way to properly check the timing). Gap the points/plugs as per the manual.
Check tappet clearance. Check float level. Check for good fuel flow from petcock and to carb float bowl (dirt can fill in behind the float needle seat, causing flow restriction).
New spark plugs, or sandblast clean and test the plugs using a plug tester. Just because the plugs spark when resting on the head doesn't mean they'll spark under compression.
Check the coil for resistance using an ohm meter (plenty info online).
Hondaboy
Post by Hondaboy » Wed Jun 29, 2016 10:14 pm
Thanks I am going to go through and double check everything again.
