Major Engine Components
Posted: Mon Feb 06, 2012 5:52 pm
Ok, I have all the major engine components out and cleaned and am ready to start ordering parts, gaskets/seals, have some minor machine shop work done, etc., but I have a couple of questions.
This is a 1965 Superhawk, Ser # CB77E-1003824
1. Which right side engine cover do I get? 11330-268-020 or 030? I ask because the Bill Silver Engine Repair Guide, on page 2, breaks down the Honda model code as 275 for CB77 and 268 for CB72. The part number for both covers is for 268. I am pretty sure I need the 030.
2. I earlier posted photos of the rocker arms and tappet adjusting screws, do these look ok? is there excessive wear rocker arm pads and are the tappet screws too "Flat".
3. Is the oil pump in good shape? all the tolerances were good according to specs for the gears, etc.
I will take the cylinder head to a local machine shop for dipping, valve seat check and lapping the valves, and to hone the cylinders. One major component I will need to replace is the left camshaft as the tach gear has stripped the end of the camshaft and totally chewed the gear in the left side cover tach gear (see Photos)
