Starter Clutch question.......
- jleewebb
other end
I think I must have misunderstood original poster...this applies to sprocket on starter motor itself, and planetary reduction gears behind it...sorry if I confused anyone...
'62 CB77. "It's a rider."
rzgkane
Re: other end
It still makes little sense, then, because you can remove the starter motor's sprocket and reinstall it without any problems as far as I've experienced.jleewebb wrote:I think I must have misunderstood original poster...this applies to sprocket on starter motor itself, and planetary reduction gears behind it...sorry if I confused anyone...
1965 CA77Dream
Re: starter clutch
Your two cents won't pay for the parts you recommend.
Although they don't cost a lot why waste money when they are good to use?
Or maybe you will pay for them so the feller can have new ones. ........lm
rzgkane wrote:If you are going through the hassle of replacing the starter clutch springs, you should sure as hell spend the other $10-15 and replace the rollers and cups while you're in there, especially since you can buy them from your local HONDA dealer. Just my two cents.brcree wrote:Tom has some new springs on there way to me.....will see if this quits things down.
rzgkane
Re: starter clutch
My worry is that an old cup or roller (because they've got maybe a little corrosion on them?) binds up here and there causing the clutch with the new springs to malfunction. If that happens, he will be wishing he had spent the extra few bucks on the additional new parts as he disassembles the right cover again. That's all. To each his own.LOUD MOUSE wrote:Your two cents won't pay for the parts you recommend.
1965 CA77Dream
Re: starter clutch
So you qualify " because they've got maybe a little corrosion on them? binds up here and there causing the clutch with the new springs to malfunction".
I'm sure any of this is visible if there and then parts can be ordered.
Any recommendation as to how to clean the area where the springs and caps install?.............lm
rzgkane wrote:My worry is that an old cup or roller (because they've got maybe a little corrosion on them?) binds up here and there causing the clutch with the new springs to malfunction. If that happens, he will be wishing he had spent the extra few bucks on the additional new parts as he disassembles the right cover again. That's all. To each his own.LOUD MOUSE wrote:Your two cents won't pay for the parts you recommend.
rzgkane
Re: starter clutch
I'd use a pipe-cleaner type brush and some WD40 for cleaning the bores where the springs and caps reside. I've seen brushes of this type with light metal fibers in them that would probably do the job quite well. What would you recommend?LOUD MOUSE wrote:So you qualify " because they've got maybe a little corrosion on them? binds up here and there causing the clutch with the new springs to malfunction".
In the end it really is a matter of style and budget. I'm the type of person that replaces everything within financial reason if I'm tackling a job just because doing it over stinks. "Financial reason" varies from person to person and from bike to bike.
1965 CA77Dream
Re: starter clutch
rzgkane wrote:Now we are into it.LOUD MOUSE wrote:So you qualify " because they've got maybe a little corrosion on them? binds up here and there causing the clutch with the new springs to malfunction".
Identify any bad parts.
Clean the others and order the parts you actually need?. ..........lm
