Exessive engine noise
48lesco
Post by 48lesco » Mon Jun 24, 2013 3:44 pm
The motor has to come out of the bike and the top end torn down to replace the cam chain. A couple of points here... If the cam chain needs to be replaced, I would tear it down anyway to have a look at the rings, valves, etc. I would consider replacing my mechanic too if he were asking these kinds of questions...
daywalker
Post by daywalker » Mon Jun 24, 2013 3:59 pm
He hasn't worked on these bikes before. He builds motorcycles and sells them. He has a good knowledge of motorcycle mechanics. He just had that one question about the motor. It is a 47 year old bike after all. I didn't expect him to know everything about it. Thanks for the info!
conbs
New mechanic
Post by conbs » Mon Jun 24, 2013 4:13 pm
I agree with 48. If he can't look at your bike and tell you that the motor needs to come out to get at the timing chain he may not be the right guy.
BTW How did he decide that your cam chain was the culprit?
daywalker
Post by daywalker » Mon Jun 24, 2013 4:24 pm
He found that the chain tensioner was as tight as it can go yet the noise persisted. He already adjusted the valves. Not sure what else. He told me he thought he might be able to take the gas tank off and take the engine apart while still on the bike but he was going to look into it more. I figured I'd help out by getting some info here.
cadman
Post by cadman » Mon Jun 24, 2013 4:45 pm
Here is my problem "The cam chain tensioner is as tight as it will go". The cam chain tensioner isn't "tightened" it is a spring loaded device that is self adjusting when the tensioner lock nut is loosened provided the tensioner is not frozen which can be common on these bikes.
A loose cam chain would make a noise but definitely not any kind of "clunking". The tensioner assembly is very easy to remove and check.
It is also very obvious that the top end of the engine cannot be removed without dropping it out of the bike. At this point I don't have much faith in this mechanic.
Ask him how he determined the cam chain tensioner was at its max!!
Post by G-Man » Mon Jun 24, 2013 5:04 pm
I would suggest that you and your mechanic read this before you spend those dollars....
http://www.scramblercycle.com/uploads/3 ... manual.pdf
daywalker
Post by daywalker » Mon Jun 24, 2013 8:38 pm
cadman wrote:Here is my problem "The cam chain tensioner is as tight as it will go". The cam chain tensioner isn't "tightened" it is a spring loaded device that is self adjusting when the tensioner lock nut is loosened provided the tensioner is not frozen which can be common on these bikes.
He did explain that it is spring loaded. I'm trying to relay what he told me with my limited memory and mechanical know-how. All I really know is that he told me the chain is the problem. He did tell me why he thought it was the problem, I just have a terrible memory sometimes. I guess I may have misunderstood what my mechanic wanted to figure out exactly. Maybe he was concerned with having to take the entire engine apart. I know he's does well with anything that has a motor in it. That's for sure. He has a good reputation around my area with over 30 years experience. I trust him to do the job well as he's never let me or anyone I know down before. He's also a nice guy, so I think he might be trying to give me some hope that I won't have to pay a big chunk of money to him afterward.
There's no clunking noise. Just a loud rattle. I did put new spark plugs in it and that stopped the other issues I was having. New plugs haven't fouled yet either.
