Hi Jensey
Paint and dirt? In the disassembly pictures? You can Presume I assembled the motor using basic mechanical hygiene. I don't like doing work over. Have a great day!
Steverino's CB77
Thanks Malcomb.
I plug openings rather than masking with tape. Spark plug holes with old spark plugs, intakes and exhausts with rags. It may not be everyones way but thats how I do it. Before I install the tensioner I will wipe down the flange with thinner as I had planned. It is my habit to test fit all screws nuts and bolts with my fingers before putting a driver to them to check for clear threads and to avoid galling. My clumsy method must work. This is only my first CB77 but my sixth old Honda refurb or restoration and although I've had to remove many dozens of seized and rounded fasteners I have yet to ruin a thread.
Steve
Steve
These gaskets showed up yesterday so I spent some time today cleaning up the pump and screen housing. The old gaskets were real stubborn and it took at least a half an hour with the wire wheel to get the screen housing clean. After a short nap I will head back down to the shop and take care of that flange. I am pretty sure, (I'll double check though.) the threads are okay now.
KIMG0899 by Steve Steverinomeister, on Flickr
KIMG0899 by Steve Steverinomeister, on FlickrMedia Blasting the Engine Cover
Aluminum Oxide at 100 psi
https://www.youtube.com/watch?v=LGP9K-J-i9A
The "tensioner gasket" showed up today. Ha Ha, not even close.
KIMG0929 by Steve Steverinomeister, on Flickr
