Torquing CA77 Head Bolts
garncarz
Post by garncarz » Sat Apr 19, 2014 3:41 pm
Thanks Ed. I had just replaced all the gaskets. Had it all back together. Torque wrench set: 15, 15,15,15,15,15,15, snap! F@ck! Fortunately, Lancaster Honda has 6 studs in stock.
Post by LOUD MOUSE » Sat Apr 19, 2014 3:55 pm
That's terrible.
I torque to 21#. ............lm
garncarz wrote:Thanks Ed. I had just replaced all the gaskets. Had it all back together. Torque wrench set: 15, 15,15,15,15,15,15, snap! F@ck! Fortunately, Lancaster Honda has 6 studs in stock.
garncarz
Post by garncarz » Wed Apr 23, 2014 12:55 pm
LOUD MOUSE wrote:That's terrible.
The service manual says 15#, why 21#? Also, I assume clean and DRY treads, correct?
garncarz
Re: Torquing CA77 Head Bolts
Post by garncarz » Sat Apr 26, 2014 2:05 pm
LOUD MOUSE wrote:Remove the cap nut then double nut the shaft and remove it. Check the threads for aluminum. Make sure they have the top on top as if upside down the shaft can screw in a lot farther than when it's installed correctly. .................lm
Dogsbd wrote:I was torquing the head bolts on my CA77 and 6 of the 8 all torqued up at pretty much the same number of turns. But the front outer bolts have gone several turns farther than the rest and the torque wrench still hasn't "clicked".
Is this cause for concern? Do I keep on turning regardless?
There is a top and bottom to the studs? How do you tell?
Post by G-Man » Sat Apr 26, 2014 2:43 pm
Bottom end has more threads....
The outer front studs extend more because they are smaller diameter. Just like elastic; the thinner it is the more stretchy......
garncarz
Post by garncarz » Tue Apr 29, 2014 7:01 am
G-Man wrote:Bottom end has more threads....
Got it all back together yesterday and took it fo a ride. Thank for everyone's help.
