Hi LM
Engine is not siezed, it will turn over fine on the rotor bolt. It will just not turn on the kickstart. ( I am kicking it the right way).
So looks like I will have to strip down. Can you split the crankcase without removal of barrel/ head?
Greg
Proper Kick Start Assembly--Seeking 100% Clarity
Yep. Turn the thing upside-down and you can just take off the bottom cover. Don't forget the two studs in the 'valley'. The clutch and gear selector have to come off.
GregMcN wrote:Hi LM
Greg
GregMcN wrote:Hi LM
Greg
Put the trans in neutral to prove if the clutch is stuck. .......lm
GregMcN wrote:Hi LM
Greg
