Page 49 of 55
CB77 Update, a little oil leak
Posted: Thu Feb 11, 2016 1:33 am
by Steverino
I've been slowly making some progress on the CB77. If I didn't have this leak, I would done. It's running down the upper engine case on the front left inner webbing. Here is a picture, if you look carefully you can see the drop, just ready to drop.
KIMG0415 by [
KIMG0418 (1) by
Steve Steverinomeister, on Flickr=
https://www.flickr.com/photos/127517865@N06/]Steve Steverinomeister[/url], on Flickr
The oil seems to be leaking directly above that where the flange on the upper case mates with the bottom of the barrel. I know a lot of oil is pumping up and drain back down through that area but I don't remember there being an O ring there. Just O rings on the outer bolts.
engine cases diagram (2) by
Is there something I missed here? I've done several of the smaller twins and haven't had this problem before. I was careful to clean and check the mating surfaces and to torque the head bolts. The only thing I can think of is I missed an O ring.
S
Posted: Thu Feb 11, 2016 2:56 pm
by Hoosier Tom
Steve,
There is no o-ring between the barrels and top case, only the base gasket.
HT
Posted: Fri Feb 12, 2016 1:50 am
by G-Man
Steve
Are eithe of the two knock pins sitting too proud of the case? Maybe they are a bit too long and holding the joint apart?
Posted: Fri Feb 12, 2016 2:10 am
by Steverino
Thanks HT
That could be G-Man. Thinking about those knock pins, When I assembled the engine, I figured the correct torque of the head bolts would draw them up.
I started preparing to drop the motor this afternoon and I will have a better look this weekend. I will check for gapage between the barrel and engine case in that area before I pull the top end.
Steve
Below the picture of the motor is an organizer I bought at harbor freight. I hope to do away with all the cardboard boxes I spend so much time sifting through looking for parts.
KIMG0424 by
I like how I can see all the parts without having to dig around.
KIMG0423 by
Posted: Fri Feb 12, 2016 2:45 am
by G-Man
Steve
When you have the top end off, put the barrel back on without base gasket you can then pull everything down and see if there is a gap.
Love the organizer. Spent more than a week searching fro the one kickstart gear that I knew I had. It turned up after I'd found a replacement......:-)
Steverino wrote:Thanks HT
Steve
KIMG0424 by
KIMG0423 by
Posted: Fri Feb 12, 2016 9:51 pm
by Steverino
I'm Ready to remove the top end and find out why it's leaking.
KIMG0431 by
Oil Leak Problem Figured Out
Posted: Sat Feb 13, 2016 12:31 am
by Steverino
I wish I would have noticed this when I installed it. I have the wrong gasket. I'm glad I was putting plenty of oil to the top end on the first fire up. Is there an early and a late gasket?
Steve
KIMG0436 by
KIMG0433 by
