12v continuous power is supplied to the coil. When the points open, at "F", they interrupt the current to the coil which causes the field in the coil to collapse and induces the high voltage needed to fire the plugs.Eljeef wrote:I removed the starter wire and tried to kick start my bike. I now have 12 volts at the points when they are open so I can see there is a problem somewhere in the starter circuit. I tried to kick start her and she is firing. It even backfired once. Progress! I checked the points again and I don't have power until just past the "f"notch and actually when the rotor hits the "t" notch. I will try to adjust this. Any feedback on whether this sounds like an issue?
Since your description does not seem to match what I have described, I would say it is an issue.
