cb 77 engine stuck???
Post by davomoto » Sat Oct 23, 2010 10:54 am
I tighten it with a hammer and a dull chissel.
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
Post by e3steve » Sat Oct 23, 2010 11:24 am
LOUD MOUSE wrote: Still No Answer as to How Do Ya Tighten The Nut on the Left Side of the CRANK!!!!!!!!!!!. ......lm
Catch the LEFT piston at BDC after ignition stroke (not the RIGHT -- don't want to strain the crankshaft, do we?)
  1. Pour about 50cc of engine oil into the left bore
  2. Rotate the crank c/w (from the left side) until the oil just reaches the plug 'ole
  3. Replace the sparkplug
  4. Continue to rotate the crank (remember: backwards, now!) 'till it hydraulically locks
  5. Go to eBay and Buy It Now a $450 Snap On impact gun
  6. Wait for delivery
  7. Go to local toolmaker with The Nut and get him to make a special castellated socket with a female ½" drive
  8. Tighten the nut with your new tools
  9. Strip the castellations from the 100-buck tool that your guy made for you
  10. Cry a little but eventually rest in the knowledge that the nut is now tight
  11. Take out both sparkplugs and kick the motor over
  12. Spend the rest of the evening wondering how you're gonna clean the garage ceiling/car/toolchest and anything else within 5 yards of the left side of the bike.....
Post by LOUD MOUSE » Sat Oct 23, 2010 11:55 am
I like both ideas.
However davo has a way that Is Far To Simple/Easy.
What is the part number for the socket????????. ....:-). .......lm
Post by LOUD MOUSE » Sat Oct 23, 2010 11:57 am
Now Ya Got It!!!!!!!.
KISS!!!!!!!!
Right???????????......lm
davomoto wrote:I tighten it with a hammer and a dull chissel.
jensen
Post by jensen » Sat Oct 23, 2010 12:05 pm
Hi Ed,
I hold the clutch with the Honda clutch outer tool, and then tighten the nut with the Honda 20 mm castle nut tool. (not joking, and yes I know, I have to much time and to much tools on/in my hands).
jensen
Post by jensen » Wed Oct 27, 2010 10:35 am
Hi Ed,
You asked a question about the part number of the socket.
I don't know if you asked me this question, but since no one responded :
The P/N of the socket I use for the nut is 11500108-1
Snakeoil
Post by Snakeoil » Wed Oct 27, 2010 5:03 pm
I make my own castle nut sockets from Taiwan sockets. Used tool store in town sells used Taiwan sockets for 50 cents to a dollar. Sometimes if they are in a good mood, they just give them too you. Using a Dremel and a small cut off wheel, I just make the 4 lugs by cutting away the socket. I clean them up and do the final fitting with a small file. If it breaks, I spend another 50 cents and make another. If you make them right, they hold up pretty well. After all, how many times you gonna need this socket??
regards,
Rob
