1. How do you keep the bolt for the foot peg and the shift lever tight, but not too tight which causes the lever to stick in place. My concern is that the bolt would work it's way out leading to an unfortunate accident if there were ever a time when most of your weight was on that peg.
2. After boiling the rubber stopper for a good amount of time to loosen and expand it, I tried getting it onto the center stand. Even after boiling it took so much force and twisting to get on half way that I could see the powder coat rippling. I was thinking of trying it again with the addition of some sort of lubricant, but I've gotta say; it was brutally tight the first try. What methods do you use?
Here's a quick shot of the linkage moved back.
