Yeah, I have this old tuning book (yellow cover) but it doesnt really give me much information thats helpful! :/
Sascha
Carb Rebuild - putting back together.
As you look at the side of the carb with screws, one on the left (angled) is air idle mixture.Sascha wrote:Yeah, I have this old tuning book (yellow cover) but it doesnt really give me much information thats helpful! :/
Sascha
The one on the right is the idle speed screw.
Left screw..screw in till lightly seated, then back out 1 1/2 turns
Right screw does essentially the same thing as opening the throttle (actually sets how open it is when the hand throttle is closed)
Turn it in while observing the slide, and stop just when you can see the slide starting to move up.
Make sure you have the carb float set to 26.5mm before you re-install carb.
This applies to CA models with single carb.
marlin4622
brewsky,brewsky wrote:As you look at the side of the carb with screws, one on the left (angled) is air idle mixture.Sascha wrote:Yeah, I have this old tuning book (yellow cover) but it doesnt really give me much information thats helpful! :/
Sascha
are you suggesting that you adjust the carbs without the air intake hose on so we can see the inside of the carb?
also, you are referring to the needle slide ?
No...just referring to the initial setting to start with,.....I do this before even putting the carb back on after cleaning.marlin4622 wrote:brewsky,brewsky wrote:As you look at the side of the carb with screws, one on the left (angled) is air idle mixture.Sascha wrote:Yeah, I have this old tuning book (yellow cover) but it doesnt really give me much information thats helpful! :/
Sascha
Carb adjustment should be done with the engine up to operating temp and air cleaner attached.
Yes, I am referring to the slide...it's hard to see when the air cleaner is attached, so I adjust it before installation
marlin4622
looking for the clip
Hi I am looking for a carb clip which holds lower bowl of the PW22 carb. Also a rebild kit can some provide some info.
Thanks.
Thanks.
