Page 8 of 15
Posted: Sat Nov 29, 2014 4:56 pm
by jugger18
Well I just carried the engine to the basement :) That was fun...said no one ever. I have to deal with stuck/frozen screws on the clutch cover
Posted: Sat Nov 29, 2014 8:10 pm
by Waveblaster
impact driver for the tricky ones.
Posted: Sat Nov 29, 2014 8:19 pm
by jugger18
Yeah. I bought one but have not had much luck with it so far. It was a cheap one from harbor freight
Posted: Sat Nov 29, 2014 9:41 pm
by ahenthus
The HF impact you're using probably has Phillips bits. You need to buy a JIS bit set. JIS will fit the fasteners properly and you should get much better purchase whereas the SAE bits you're using cannot make full contact with the fasteners because they're designed to cam out. JIS bits are readily available.
Posted: Sun Nov 30, 2014 7:39 am
by LOUD MOUSE
Where can I get JIS bits for a Hammer Drive?. .......lm
ahenthus wrote:The HF impact you're using probably has Phillips bits. You need to buy a JIS bit set. JIS will fit the fasteners properly and you should get much better purchase whereas the SAE bits you're using cannot make full contact with the fasteners because they're designed to cam out. JIS bits are readily available.
Posted: Sun Nov 30, 2014 9:00 am
by R100
http://www.vesseltools.com/hand-tools/s ... ducts.html
LOUD MOUSE wrote:Where can I get JIS bits for a Hammer Drive?. .......lm
Posted: Sun Nov 30, 2014 9:49 am
by LOUD MOUSE
Thanks.
I ordered the 2400 set. ......lm
R100 wrote:http://www.vesseltools.com/hand-tools/s ... ducts.html
