Page 8 of 24
re:
Posted: Fri Apr 13, 2012 3:42 pm
by Mike Mullins
Jon: It's ALL easy ! (small joke) Actually its not that bad- just don't get in a hurry and keep track of everything. ( I always find something that should have gone back in one or two steps ago.) I think you'll have that great running bike I told you about when you get the advance springs sorted out.
(How did the carbs work ?)
Mike
Posted: Fri Apr 13, 2012 4:04 pm
by Jlovvorn
Springs bent and replaced, tensioner removed cleaned and put back.
Working on the starter now.
The carbs seem good, but the test will be when it fires back up.
I didnt realize I needed to drain the oil before this, and the head is starting to leak because the top cover is off. Is this bad? or will it just tighten back up?
Will post pictures later of whole process.
Posted: Fri Apr 13, 2012 4:57 pm
by rzgkane
Jlovvorn wrote:Springs bent and replaced, tensioner removed cleaned and put back.
What're you doing with the starter?
Posted: Fri Apr 13, 2012 5:53 pm
by Jlovvorn
Starter is non-op. Could not figure it out. Bolted back on for later repair.
Anyone know what to tighten the cap bolts down to? Is there a particular torque?
Thanks.
Posted: Fri Apr 13, 2012 5:57 pm
by Jlovvorn
Pic of the legendary neoprene on the advance weights...
Posted: Fri Apr 13, 2012 6:46 pm
by rzgkane
I looked at the advance unit on the spare motor I have and I found that the neoprene was indeed there, although half of each piece was missing from both of the weights. See below:
IMG_0834 by
rzgkane, on Flickr
Re: Pic of the legendary neoprene on the advance weights...
Posted: Fri Apr 13, 2012 7:07 pm
by LOUD MOUSE
That looks like a DREAM sprocket. ???????????????
I don't recommend ya use it in your engine.
It's a small bit not over the entire outside of the part.
If ya can lift it and sort of allow it to snap back and don't hear a metallic sound (sort of a CLUNK) ya are OK. ......lm
rzgkane wrote:I looked at the advance unit on the spare motor I have and I found that the neoprene was indeed there, although half of each piece was missing from both of the weights. See below:
IMG_0834 by
rzgkane, on Flickr
