Dianne's C77
DianneB
Post by DianneB » Mon Aug 10, 2015 4:56 pm
I am not absolutely sure but the plugs look slightly wet. There is gas in the float bowl and I have cleaned the carb a second time with no change.
Post by G-Man » Mon Aug 10, 2015 5:00 pm
Battery charged?
Points clean?
Are you using electric start or kick?
Just trying to think of things that may have changed since you had it running...... :-)
DianneB wrote:I am not absolutely sure but the plugs look slightly wet. There is gas in the float bowl and I have cleaned the carb a second time with no change.
DianneB
Post by DianneB » Mon Aug 10, 2015 5:48 pm
G-Man wrote:Battery charged?
Fully. I charge it every time I have tried to start it.
Points clean?
Yup, checked them for continuity to set the timing. Then switched to electronic ignition with now change (but stronger spark) - didn't make any difference.
Electric - my kick starter isn't working.
ME TOO! I touched absolutely NOTHING between the last time it ran and when it wouldn't start any more!
Post by G-Man » Mon Aug 10, 2015 5:58 pm
Just looking back through your posts. Wondering about the tank sealer.......
Points clean?
Post by G-Man » Mon Aug 10, 2015 5:59 pm
Just looking back through your posts. Wondering about the tank sealer....... Could it be softening and getting into tap or carb?
Points clean?
sarals
Post by sarals » Mon Aug 10, 2015 6:41 pm
Did you try squirting a little bit of gas into the carb inlet?
1965 CB77 305 Super Hawk
1989 NT650 Hawk GT
1981 Yamaha XJ550 Seca
DianneB
Post by DianneB » Mon Aug 10, 2015 7:06 pm
The tank sealer is solid - nothing showing up in the filter.
Will try some IV gas tomorrow ;)
