1966 CB77 Restoration Project
Post by Seadog » Sun Feb 11, 2018 9:08 pm
You and Geoff were right, LM. Thanks to you both for solving the little mystery.
LOUD MOUSE wrote:I'm a bit late with my answer as I was the one who suspected it was a gear cotter and asked to see the other side.
What did you see before I asked ? ??????????????????lm
Post by Seadog » Fri Feb 16, 2018 10:31 am
Cleaning parts today, but primarily carburetors. I scored a pair of badly corroded Keihin PW26s for the parts i needed. I found that the PW26s that came with the bike (but not mounted on the engine) have CL77 stamped on their flanges, but no matter, they'll get the correct jets.
I had to scrape the dried grease and dirt from them, then washed them in kerosene, then a night in a gallon can of carb cleaner, a day in a gallon can of lacquer thinner and now in an ultrasonic bath. They'll get a rinse and i'll blow them out with compressed air and check that the passages are clear. When the parts kits arrive, they'll be reassembled and set aside for later.
Post by G-Man » Fri Feb 16, 2018 12:56 pm
They'll look superb after all that treatment!
Seadog wrote:Cleaning parts today, but primarily carburetors. I scored a pair of badly corroded Keihin PW26s for the parts i needed. I found that the PW26s that came with the bike (but not mounted on the engine) have CL77 stamped on their flanges, but no matter, they'll get the correct jets.
Post by Seadog » Fri Feb 16, 2018 1:27 pm
Thanks, G. I don't know if they're superb, but they'll do.
Post by LOUD MOUSE » Fri Feb 16, 2018 5:26 pm
I think these are the carbs wit the nylon slide centering guide.
You have done a lot of cleaning with chemicals so may want to see if they are still there. ......................lm
Post by Seadog » Fri Feb 16, 2018 5:57 pm
Learn something new every day. Thanks, LM. One is nylon and the other is metal. Both are there. What's the reddish brown stuff Keihin painted on hold the metal guide in?
LOUD MOUSE wrote:I think these are the carbs wit the nylon slide centering guide.
Post by LOUD MOUSE » Fri Feb 16, 2018 8:31 pm
Beats me.
I think it's more of a sealant than a glue. ..................lm
Seadog wrote:Learn something new every day. Thanks, LM. One is nylon and the other is metal. Both are there. What's the reddish brown stuff Keihin painted on hold the metal guide in?
